0.8mm Pitch fanout BGA solder mask expansion
Hello Aisler. I am working with a LFBGA-196 with 0.8mm pitch and 0.38-0.48mm solder ball size. I am looking at creating a bog bone fanout to avoid having to plug the vias.
NXP recommends a solder mask opening of 0.44mm and a land pattern of 0.34mm. This results in an expansion of 0.05mm on the BGA pads.
What is the recommend setup for the 6+ ENIG board. I have tested 0.45mm vias and 0.25mm holes, but with 0mm solder mask expansion on vias, the sliver between the via and pad is less than 0.1mm. Should I cover the annular ring partially with solder mask with an negative solder mask expansion on the vias? Or would it make more sense to plug the vias?
Also, with a hole to copper clearance of 0.25mm, 0.25mm via hole size and 0.8mm results in only 0.05mm for route traces between via-in-pad under the bga in tight area, is this a hard limit?
Thank you, Best regards
