2 Layers 1.6mm 70µm Stackup Matierial Dielectric constant: height
What is FR4 material dielectric constant and height which will be used into standard 2 Layers 1.6mm 70µm Stackup?
Hey @Ronak-Shah
I moved your question to the correct category :slight_smile:
This post describes that it is variable - if you need a specific dielectric constant and height for you project I’d recommend to get in contact with our support.
