Compact Power and Safety: Inside UgentRacing’s Custom LV Box
In Formula Student, speed means nothing without absolute reliability. Thanks to our partnership with Aisler, UgentRacing has brought a highly integrated Low Voltage (LV) box to life. Aisler’s rapid prototyping and precision manufacturing allowed us to seamlessly connect our Engine Control Unit (ECU), Shut Down Circuit (SDC), and Brake System Plausibility Device (BSPD) PCBs using board-to-board (b2b) connectors positioned along the sides of the boards. This clever packaging saves vital space and eliminates a messy, fragile wiring harness. Here is a look at the architecture of our custom LV box and how these boards work together to keep our car safe on the track.
Engine Control Unit (ECU): The Master Node
Our ECU acts as the master node on the vehicle’s CAN bus, dedicated to system supervision and seamless communication.
  • Heartbeat Detection: The ECU continuously monitors periodic signals from critical modules like the Battery Management System (BMS), Inverter, and Dashboard. If any module drops offline and misses a “heartbeat,” the ECU instantly triggers a safety state.
  • Inverter Command & Control: The ECU is responsible for translating the driver’s inputs and the car’s dynamic state into precise torque requests. It calculates and sends these high-speed control signals directly to the inverters, dictating exactly how much power is delivered to the motors at any given millisecond.
    Shut Down Circuit (SDC): The Safety Shield
    The primary function of the SDC PCB is to physically monitor and close the shutdown loop. However, its tight interface with the ECU dictates the vehicle’s overall safety and Ready-to-Drive (RTD) state.
  • State Monitoring: The ECU actively reads whether the SDC circuit is open or closed in real time.
  • Safety Confirmation: Before the driver can start the car, the ECU must transmit a “Low Voltage OK” signal to the SDC safety logic. If the ECU detects an internal fault or a missing heartbeat, it withholds this signal, actively preventing the car from ever entering a high-voltage state.
Brake System Plausibility Device (BSPD): The Hardware Gatekeeper
Imagine a scenario where a driver panics or a sensor fails, causing the car to receive full throttle and hard braking commands at the exact same time. In a high-powered electric racecar, a motor fighting the brakes is a recipe for disaster. That’s where the BSPD steps in to save the day.
Because software can occasionally freeze or glitch, Formula Student rules demand a pure hardware gatekeeper. The BSPD is our unhackable, non-programmable electronic referee. It constantly watches two things: the pressure in the brake lines and the electrical power being delivered to the motors.
If the BSPD’s analog logic detects an “implausible” scenario—specifically, hard braking while the motors are still drawing high power—it takes immediate action. It drops its baseline BSPD_OK signal and triggers a hardware latch. This instantly forces the SDC open, safely killing the high-voltage tractive system in milliseconds. Once the BSPD trips, the car is dead in the water until a human manually presses a physical reset switch. It is the ultimate failsafe, ensuring that no matter what goes wrong, the car will always stop safely.
By using side-mounted b2b connectors inside our LV box instead of a tangled mess of loose wires, the signal paths between our ECU, SDC, and BSPD are incredibly short. This makes them highly resistant to track vibrations and completely immune to pin-out errors during frantic trackside maintenance.
Designing dense, mixed-signal boards to fit perfectly together requires absolute faith in your PCB manufacturer. Aisler delivered exactly what we needed: flawless, track-ready hardware. Thank you to the Aisler team for supporting UgentRacing and helping us engineer a faster, safer vehicle!
