DaVinciBot, PAMI Controller Board: A custom ESP32-S3 motherboard for our small autonomous robots
DaVinciBot, the student robotics association at ESILV (Paris & Nantes, France), redesigned the main controller board for our PAMIs (small independent secondary robots) around an ESP32-S3. This post goes over what went wrong with last year’s board, how we fixed our power rails and ESD issues, and what we learned from testing this first prototype with Aisler’s support.
DaVinciBot is the student robotics team from ESILV (École Supérieure d’Ingénieurs Léonard de Vinci), split between our Paris and Nantes campuses. Every year, we design and build fully autonomous robots for the Coupe de France de Robotique (the French branch of Eurobot). Alongside our main robot, the competition rules require us to deploy a fleet of smaller autonomous robots called PAMIs at the end of the match. This board is a complete rework of last year’s PAMI PCB. The goal was pretty straightforward: fix the annoying hardware issues we faced last season mainly underpowered stepper motors and fried microcontrollers to get a reliable motherboard that is easy for the team to use and debug.
The project
This PCB acts as the brain and power distribution hub of our PAMIs. Built around an ESP32-S3, it packs motor control, sensor interfaces, and wireless communication into a single compact footprint:
  • Locomotion: Two plug-in sockets for TMC2209 stepper motor drivers (left and right wheels).
  • Actuators: Two PWM headers for standard servomotors.
  • Navigation: A dedicated connector for a LIDAR sensor to handle local obstacle detection and mapping.
  • Communication: A UART header for a LoRa module. Even though the playing table is only 2x3 meters, we chose LoRa over the ESP32’s built-in Wi-Fi because competition venues are packed with dozens of teams, which heavily congests the 2.4 GHz Wi-Fi bands. Using LoRa which is much less common at these events lets us avoid radio interference and reliably exchange data between the PAMIs, our main robot, and our external camera beacon (an elevated camera mounted on a stand beside the playing field that tracks game elements, our robots, and opponent positions in real time).
For now, high-power conversion is handled by a separate power board connected to this motherboard.
The Electronics
Most of our design choices come directly from the lessons we learned the hard way last year:
  • Splitting the power into three rails (+Vin, +5V, +3.3V): Last year, we made the mistake of running our stepper motors off a 5V buck converter. The voltage was way too low, so the motors had no torque and struggled to move the robot properly. On this new version,we split the power distribution into three separate lines: a direct +Vin rail fed straight from a 4S LiPo battery for the TMC2209 stepper drivers, a +5V rail for servos and 5V peripherals, and a clean +3.3V rail (regulated via an onboard AP2112 LDO) dedicated to the ESP32-S3 and logic.
  • Adding ESD protection: Last season, we killed several ESP32s just by handling the board or plugging cables in and out due to electrostatic discharges. To stop frying boards, we added a USBLC6-2SC6 protection IC right on the USB Type-C data lines—which works great, flashing is completely reliable now and an SC3402-02ETG TVS diode on the power input to absorb voltage spikes and current surges.
First prototype feedback & next steps:
While the new 4S power architecture and USB protection work like a charm, assembling and testing this first revision highlighted a few classic hardware traps that we plan to fix on Rev 2:
  1. Package size vs. hand-soldering: The SC3402-02ETG ESD diode we picked for the power rail is tiny. It is a real pain to solder by hand in the lab, so we will switch to a larger footprint on the next spin.
  2. Broken Enable / Boot circuit: We made a wiring mistake on the Reset/Enable button, which causes boot glitches on the ESP32. We will rework the ground routing and pin connections by strictly following Espressif’s hardware design guidelines.
  3. Quality-of-life fixes: We plan to add a jumper between the external 5V rail and the onboard AP2112 3.3V LDO so we can power the ESP32 directly from the 5V line without needing an external 3.3V supply. We are also adding a proper dedicated connector for the robot’s starting pull-cord (last year, it was hack-wired directly onto spare pins of the LoRa header).
  4. Merging the boards: Down the road, we want to merge the separate power board directly into this motherboard to save space inside the robot and get rid of redundant 3.3V regulators.
Having Aisler as a partner makes a huge difference at this stage: being able to get the boards quickly, test them on the workbench, catch our footprint and boot-circuit mistakes early, and order a fixed revision keeps our hardware schedule on track before the competition.
Open Source
Our KiCad files and documentation will be shared with the community. Hopefully, our notes on ESP32-S3 protection and stepper power routing can save other student robotics teams from burning a few microcontrollers!
A big thanks to Aisler for supporting DaVinciBot with fast and reliable European PCB manufacturing.
