Ecurie Aix - Car Testbench
We are Ecurie Aix, the Formula Student team from RWTH Aachen. We design and manufacture a fully electric race car to compete in Formula Student competitions against teams from other universities from around the world. For our electronics, we design and use many different PCBs throughout the entire vehicle, that are all kindly supported by AISLER. One such board is our Testbench, which is presented in this article.
To make our car as reliable as possible at events, we test as much of the system as we can outside the vehicle. This includes a full system test with all low-voltage PCBs set up on a table. So that we donโ€™t need a finished wiring harness and packaging at that stage, we designed a PCB that replaces the harness and connects all components directly to each other. This lets us test the dependencies between our boards and confirm that everything behaves as expected.
The board offers multiple screw terminals for connecting the individual components. It also carries rule-mandated parts, such as the Master Switches that turn the vehicle on and off. Our Electronic Control Unit (ECU) can be plugged in directly, which makes powering and testing it much easier. To verify that sensor evaluation works correctly, we can connect real sensors or simulate their signals to keep the test setup simple.
This setup lets us test our code in advance. We find mistakes faster and avoid the risk of damaging something by testing directly on the car. It also gives the mechanical groups more time with the vehicle, which is worth a lot given the short time we have to build and commission it.
In advance, we can check how the PCBs interact and whether buttons and rotary switches work as intended. We can also verify that our high-voltage interlock works and that we can reliably locate where it opens in the event of failure.
These abilitiies bring significant benefits to our development. It shortens commissioning time, giving us more time to test the vehicle, and that translates directly into better performance on track. We are very grateful to AISLER for enabling us to get the absolute best out of our car!
