eUSRacing, Design Phase of Our Electric Motorcycle for MotoStudent
Hello everyone!
We are eUSRacing, the electric motorcycle racing team from the University of Seville, Spain. Around 50 students from engineering, physics, business, and computer science work together over two years to design, manufacture, and race our own electric motorbike prototype at MotoStudent, the world’s largest university motorcycle competition, held at the FIM MotorLand Aragón Circuit.
Every team builds a real racing motorcycle from scratch and competes in a 7-lap race, as well as in static phases covering innovation, design quality, and industrial viability. We compete exclusively in the MotoStudent Electric category — a decision we made back in 2019 and have never looked back on.
Our goal for this season
We are currently in our design and manufacturing phase, working toward our next prototype, the 9th motorcycle in our history and the continuation of our electric journey. Our main goal this cycle is to address the lessons learned from our previous edition, where manufacturing delays and controller reliability issues prevented us from fully showing what our prototype was capable of. This time, we are designing with reliability and testability as first-class requirements from day one.
Electronics: the nervous system of our motorcycle
In the development of a competitive electric motorcycle for MotoStudent, electronics are the nervous system that determines both on-track performance and the safety of the rider and mechanics. Thanks to AISLER’s support, we have been able to bring several custom PCBs to life with industrial manufacturing standards, optimising space, weight, and above all, reliability in an environment as demanding as a racing circuit.
We work across the full spectrum: from high-power boards handling significant currents in the motor control and battery management systems, to low-power boards dealing with sensor signals and CAN bus communication. Some of our most demanding designs involve signals that are extremely sensitive to electromagnetic noise — which requires very careful attention to layer stackup, ground planes, and shielding strategies, given how close the high-current motor phases run to the rest of the electronics.
Below, we detail the four main PCBs that make up our prototype.
  1. Power Distribution Module (PDM) — intelligent and clean power management
    The PDM is responsible for the entire vehicle’s low-voltage power distribution. It acts as the central power hub, supplying the required voltages to critical subsystems such as the ECU, BMS, inverter logic, and active cooling system.
    • Active protection: It integrates protections against overvoltages, overcurrents, and transient spikes to safeguard sensitive components.
    • Signal integrity and EMC: Designed to mitigate electromagnetic noise coupling from the motor’s power stages.
    • Wire harness optimisation: By centralising load distribution and switching on a single board, we dramatically reduce total cable length — minimising failure points caused by mechanical fatigue and simplifying assembly and maintenance in the pits.
  2. Custom High-Voltage Charger — power and recharging efficiency
    For the high-voltage battery pack, our team has developed its own high-power charger — making us one of the few teams in the competition to design our own charging system from scratch. This PCB manages conversion stages involving high currents and elevated voltages, requiring strict thermal control and careful track dimensioning (copper weight and dielectric insulation).
    AISLER’s manufacturing precision allows us to guarantee the repeatability and quality of wide tracks and thermal planes, achieving a fast and safe charging rate that minimises turnaround time between free practice and qualifying sessions.
  3. Electronic Control Unit (ECU) & DAQ — the telemetry and control core
    The ECU is the brain of the prototype. It houses the main microcontroller and its signal conditioning stages for real-time data acquisition (DAQ).
    • Telemetry and analysis: It collects data on vehicle dynamics, suspension, throttle, temperatures, and powertrain states via communication buses (CAN bus) and analogue/digital inputs.
    • Noise immunity: In an environment with high-frequency switching generated by the inverter, the quality of the layer stackup and continuous ground planes manufactured by AISLER are fundamental to preventing data packet corruption and false sensor readings.
  4. High Voltage Disconnection Circuit (HVD) — functional safety and redundancy
    Safety in a high-voltage prototype is non-negotiable. The HVD board is an integral part of the safety interlock loop and is directly responsible for governing the immediate opening and disconnection of the high-voltage system (HVS) contactors in the event of any critical anomaly — whether that’s an emergency stop activation, an insulation fault, or a BMS cut-off command.
    Having a PCB manufactured to strict tolerances guarantees the full mechanical and electrical reliability of the actuation lines, giving both the rider and the pit crew complete confidence that the system will isolate high-voltage energy instantly and deterministically in the event of any failure.
Working with AISLER
Beyond the technical benefits of each individual board, having AISLER as a sponsor has changed how we approach the entire development process. The flexibility to order a single board, validate it, and have a corrected version back within days is invaluable for a student team working against a tight two-year deadline. The PCB viewer and rendering guarantee let us catch import issues before committing to production.
We are now deep in the design phase and will share more about our manufacturing and testing experience in future posts. If you are also working on EV powertrains, battery systems, or noise-sensitive electronics, we would love to connect!
@eUSRacing
