Hello there
we are Green Lion Racing, the Formula Student Team from University of Wuppertal.
Currently we are in the process of manufacturing our second electric vehicle. With this iteration we also have many more PCB projects to finish.
The display CAN & power board
One of these PCBs is a simple adapter board for our display to provide it with the correct power levels and a CAN transciever. Also it has a planned function to wire all steering wheel buttons and rotary encoders, so the display can convert them to CAN signals. This project is the fourth (or fifth in development
) revision of this board. With each revision we made the design sturdier and modified it to our current needs.
Electronics and design
Regarding what is happening on this board:
- On our vehicle we use a 24V power supply, so this needs to be converted to 6-9V input range for the specific display unit we use.
- A CAN transceiver and its filtering, provides the display to intake data from the vehicle to show to the driver.
- Analog input devices like buttons and rotary encoders are possible to be connected but arenโt a must.
So a pretty much a straight forward design. Therefore we also just used a standard PCB configuration without any changes.
We use KiCAD to design most of our PCBs, this one can be publicly found at this git repository.
The display unit we use for this project is the STM32F469I-DISCO development board. It already proved a good use case in our last three race cars. (One of which was still a combustion vehicle)
Problems we encountered
While still being such a simple board, it was not build without problems.
For instance having just one capacitor at the wrong location or a bit out of acceptable values in your schematic, this resulted in a not working as expected buck converter. Thus some hours of trial and error followed to find the simple error.
The obvious thing you should do and future
You should always review the PCB and schematic before ordering it, and if you solder it manually you should test throughout not to have any solder bridges, it may be that I lost one PCB to a short, but who knows?
Currently there is already the next iteration of the PCB is in development since optimisation to do have been found. As example to put most of the components on to the back side, since these would be then covered and contained in the empty space between the PCBs and connectors.
