Have a Look at TU Berlin's GaN-Based Double-Pulse Test Setup
Hello Aisler Community!
as part of a bachelor’s thesis, a GaN-based double-pulse test setup was developed to investigate the dynamic Ron under different operating conditions.
GaN power semiconductors enable very fast switching transitions and high power densities. At the same time, their Ron can change dynamically depending on the previous switching state and operating conditions.
The developed setup is used to investigate the dynamic Ron at different device temperatures and under both hard- and soft-switching conditions. This enables a direct comparison of the dynamic Ron at different temperatures and switching conditions.
Special attention was paid to the PCB layout, since the high switching speeds of GaN devices require very low parasitic inductances. Therefore, an internal vertical PCB layout with a short current path through the layer stack was implemented to minimize the commutation loop inductance. The board was designed in KiCad and manufactured by AISLER.
The setup provides a practical platform for gaining a better understanding of dynamic Ron and the behavior of GaN power semiconductors under realistic switching conditions.
A big thank you to AISLER for supporting the project!
:orange_heart: Thank you for showing us the project @Benedikt It took less than half a year, if I’m correct? Awesome! Is the thesis already handed in?
Hey Sarah,
you’re right!
The student has been working very hard on setting up the test and now has results. He will submit his work at the end of the month.
In the upcoming theses, we would like to conduct further studies of the transistors to derive simulation models.
Thanks for your support!
