In this post, we will introduce task-specific subsystem of the KALMAN rover: the water extraction subsystem, designed for the Space Resources task of the Australian Rover Challenge. One of objectives during this task is to excavate a frozen soil sample and estimate the water content of the sample.
The approach we took was to measure the mass of the excavated frozen sample, evaporate the frozen water and then measure the volume of the extracted water. The subsystem includes three main components: a heating chamber, a condenser tower with a water collection container, and a custom PCB.
The water extraction subsystem differs from other KALMAN subsystems because it is not a part of the rover itself, but rather a standalone station. This fact forces the need for different communication interface with the rover, rather than using CAN bus, the communication is realized via radio side-link using ESP32-S3 modules integrated into the rover’s miniRack Master module and the water extraction station.
To handle the complex thermal and mechanical requirements of the station, the PCB power and sensing architecture is broken down as follows:
- Heating: The heating chamber uses two custom-made PTC heaters: a main heater (200W at 24V) and an auxiliary heater mounted on the lid (50W at 24V). Switching is handled by high-power Infineon BSC026N04LS MOSFETs and a TI UCC44273 low-side gate driver.
- Cooling & Fluid Flow: The condenser tower is cooled passively using a large surface area. Fluid flow is forced using a pump driven by the same switching circuit as the heaters, with addition of fly-back diode to prevent back-emf current flow through closed MOSFET.
- Power Management: The power section includes two 5A DIODES AP64500SP DC/DC converters. These convert 24V to 12V for the gate drivers, and to 5V for remaining peripherals. Further conversion to 3.3V for the microcontroller and sensors is handled by TI TLV75533PDBVR low-dropout (LDO) regulators.
- Mass Measurement: The heating chamber is mounted on two load cells to measure the sample’s mass. These are read using a TI ADS122C04IPWR 24-bit SAR ADC - the same component used in the Universal module introduced in one of our previous posts.
- Temperature Sensing: Measurements are taken with type K thermocouples read by MAX31855 integrated thermocouple-to-digital converters. This abstracts the complexity of thermocouple signal processing and provides direct digital temperature readings via SPI.
- Future-Proofing: The board also includes integrated ALLEGRO A4950ELJTR H-bridge drivers and a DIODES AL8843SP switching constant-current driver. While not used in the current version, they are included for future iterations of the subsystem.
The firmware was built on top of FreeRTOS using the ESP-IDF framework, and is responsible for controlling the entire water extraction process, including switching the heaters and pump, reading sensors, and communicating with the rover. The debugging features of the ESP-IDF framework proved highly valuable during development, allowing us to easily identify and fix firmware issues as well as log the water extraction process which was invaluable for optimizing the performance of the subsystem.
The water extraction subsystem performed well during lab testing and the trial competition, successfully evaporating water from the soil sample and providing accurate mass measurements. However, there are still improvements to be made, such as optimizing the heating process for lower power consumption and minimizing the residual water trapped in the system after evaporation. We are looking forward to developing this subsystem further and testing it for next year’s Australian Rover Challenge.
This project couldn’t have been executed without Aisler’s support in producing our PCB. We are extremely grateful to cooperate with such professionals!
