The handling of revisions confuses me since the dawn of the push plugin.
Aisler does not use the Kicad revision field but attaches its own revision. First time you push a file it gets Revision 1, second push gets Revision 2 and so on, regardless of the revision set in Kicad. This Aisler generated revision is not sent back to the PCB editor, f.i. in a comment field like is done with the “AISLER Project ID: TWBPWVAF” in comment 4.
This means I end up with a PCB file that has a revision that does not necessarily reflect the Aisler revision.
Ideally I would like to see Aisler use the Kicad revision field, if filled in. That would get me a better control of which revision is used and also makes sure the Kicad variable ${REVISION} is printed correctly on the silkscreen. If using the Kicad revision is not possible it would be nice to at least get the Aisler revision back in a comment field after the push.
If I am completely missing the point of how handling revisions was meant to work please enlighten me
