HSNR Racing - Inverter Auxiliary Electronics
Hi everyone,
we are HSNR Racing, the Formula Student Team from Hochschule Niederrhein University of Applied Sciences. We are designing and building an electric race car each year and taking part in competitions internationally. We are using an Altium Designer Professional workspace to design our PCBs with great integration to the AISLER platform via the AISLER Push for Altium function.
Electronics & Design
platine_50fps
This season we developed a new Inverter Auxiliary Electronics board.
This board is located in the inverter enclosure and integrates three main functions and therefore combines the functionality of three individual PCBs developed last season.
The first and simplest function are the Body Protection Resistors. It consist of two 15 kΩ resistors, rated for up to 1 kV of dielectric withstanding voltage and 10 Watts of power. These resistors connect the tractive system to two measurement contacts. Their purpose is to protect the user by limiting the current flowing in case someone comes into contact with the measurement contacts. A short circuit between the two measurement contacts would be limited to only 20 mA. Voltage measurements are not affected by these resistors because of the high resistance nature of voltage measurements.
The second function is the discharge of the tractive system. The purpose of this circuit is to discharge the capacitors inside the inverters and lower the voltage on the tractive system as fast as possible after disconnecting the accumulator. It consists of a reed relay that is normally closed and five PTC resistors in series. The cumulative resistance at ambient temperature limits the maximum current to protect the relay and prevent a short circuit. The PTC resistors protect themselves from overheating by increasing the resistance and limiting the current further with rising temperature.
The last and most complicated part is the TSAL Red logic. TSAL Red stands for Tractive System Active Light Red and is an indicator indicating more than 60V being present on the tractive system. This circuit detects the voltage, and creates a blinking signal as an output. Because the circuit contains parts of the tractive system as well as parts of the Grounded Low Voltage System, it consists of a high voltage side and a low voltage side separated by an isolation barrier. On the high voltage side there is a voltage divider, which divides the 600V maximum tractive system voltage down to around 5V. This voltage is compared to a reference voltage. The output signal of the comparator representing 60 V on the tractive system is transmitted to the low voltage side via an optocoupler. This high signal is turned into an 3 Hz blinking signal by an oscillator on the low voltage side.
Lessons Learned
Advantages:
The board simplified the electronics inside our inverter enclosure massively by reducing the amount of boards and connections.
This is the first board where we used soldered steel spacers, which were an easy way to mount the board inside off the tight inverter enclosure.
Problems:
Since the board is mounted inside of the inverter enclosure, it is exposed to a lot of EMI.
While the old boards worked fine in the same location, the new board experienced some issues.
Possible changes for future versions:
More in-depth testing of EMI vulnerability is needed.
The isolated power supply is still more complicated than necessary, this part can be improved and simplified further.
Thank You, AISLER!
We were very thankful for AISLERs great Support and their fast manufacturing and delivery. Being able to order second iterations of boards for quick fixes and have them delivered in time can be very important and it made our life much easier not needing to worry about significant delays due to manufacturing time.
