Yes, i wasn’t that far in the process of ordering to see this.
I actually thought that ENIG would be an option for aluminium wire bonding as in my case, but way out of budget…seems not the case
The carrier board is extremely simple, Thanks a lot!
PS: From the table above it appears like budget board and ENIG finish is not combinable…
That’s right: Blitz and Budget boards always come with a HASL finish, HD (2L & 4L) always with an ENIG finish. The selection (HASL/ENIG) allows only compatible products to be selected during checkout. In your case (ENIG selected) this would be Beautiful Boards HD.
I just placed an order, and it appears that it will be about 6 day turnaround time. I wonder if I somehow need to select the “blitz” option for the two day turnaround. I just don’t know how to. I can’t seem to find the option when placing the order.
welcome to our Community! Unfortunately we do not offer 20oc copper thickness right now. I am happy to contact you as soon as we offer this specification.
When I want to calculate the maximum amperage that a specific trace on a PCB can handle by using it’s own width, what thickness should I use for this calculation: the base copper thickness or the min. processed copper thickness? (Specifically in the case of “Beautiful Boards HD 4L”)
At this moment we only support boards with a thickness of 1.6mm in our prototyping pool. If you are ordering larger quantities you can message our support regarding other thicknesses, they will create an offer for you.
I am busy uploading my first KiCAD designed PCBs, how exciting. So far, the PCBs upload and look very nice.
In KiCAD, they have a “layer alignment target” which looks like it is very useful for, well, aligning the layers and visual inspection. Do you recommend including one of those? It shows up as a drilled hole which might be a little over the top.
