We are the KuupKulgur team from Estonia. We are base at Tartu Observatory, University of Tartu. KuupKulgur is a student-developed lunar rover prototype and a technology demonstrator for developing and testing hardware for future lunar surface missions. A key part of the project is modularity: as the rover evolves, we want to be able to improve individual subsystems without redesigning the entire platform.
One of those subsystems is the Electrical Power System (EPS). As part of his Master’s thesis, Laur Edvard Lindmaa developed a new modular EPS architecture for KuupKulgur and used the prototype to investigate some of the less obvious challenges that appear when electrical and mechanical design meet. You can read his full thesis here.
The assembled KuupKulgur EPS and battery stacks. The modular prototype separates power regulation, battery management and monitoring functions across several PCBs.
Your project
The previous KuupKulgur EPS was useful for early rover development, but testing exposed several limitations. The voltage regulators had limited current capability and the rover could exceed 70 °C internally under normal operation. The original battery balancing circuit also did not balance all five cells correctly, battery-voltage telemetry was noisy, and the charging system could terminate charging prematurely.
The goal of the new design was therefore not simply to make another power board. We wanted an architecture that was easier to develop, test and adapt as the rover itself changed.
The main requirements included regulated 3.3 V, 5 V and 12 V outputs, a target of 5 A per regulator, a five-cell lithium-ion battery pack, per-cell voltage and temperature monitoring, regulator current/voltage/temperature telemetry, SPI communication and a mechanically modular PCB stack.
Electronics and design
The new EPS was divided into a central electronics stack and two battery stacks. Instead of concentrating every function on one PCB, separate layers handle voltage regulation, control and charging, USB-C power input, battery balancing, voltage measurement, temperature monitoring and protection.
For the voltage-regulation stage, three candidate regulator ICs were first evaluated on dedicated breakout boards: the LM61495, TPS56A37 and LT8643SIV. All three worked, but the TPS56A37 gave the best overall combination of efficiency and PCB area and was selected for the final regulator layer. The board also includes ADC-based monitoring of regulator voltages, currents and temperatures.
KiCad render of the EPS-v2 voltage-regulator layer. Candidate regulators were tested on breakout boards before the final design was committed to the rover stack.
The battery system uses five 18650 lithium-ion cells in series. Dedicated boards provide cell balancing and protection, individual cell-voltage measurement, temperature sensing and a 10 A fuse. The EPS controller also manages battery charging and provides housekeeping data to the rest of the rover.
One of the more interesting lessons came from the battery-pack connector. The original design aimed for hot-swappable batteries and used spring-loaded pogo pins between the battery and EPS stacks. On paper they looked ideal: compact, relatively high-current, and rated for many mating cycles.
In the assembled prototype, however, keeping the pins aligned proved difficult. Pins could bend or move away from the contact pads during assembly, and misalignment could place battery voltage onto nearby signal lines. Some of these shorts damaged electronics during development.
Mechanical failures observed in the original pogo-pin battery interface. Misalignment could bend the contacts or cause unintended electrical connections.
For this prototype we decided that reliability was more important than hot-swapping. The pogo-pin interface was replaced with permanent soldered connections, after which testing could continue without the same connection failures.
Tips, tricks & offers
Two practical lessons from this development may be useful for other PCB projects.
First, test critical power components independently before committing them to the complete board. Building small regulator breakout boards made it possible to compare real efficiency and behaviour rather than relying only on datasheet values.
Second, validate connectors mechanically as early as possible. Current rating, contact resistance and mating-cycle specifications only describe part of the problem. In a tightly packed system, alignment tolerances, assembly sequence and the consequences of a single misplaced contact can be just as important as the electrical specification.
The same applies to modularity in general: a removable module is only useful if the interface remains reliable after repeated real-world handling.
CTA
We are continuing to improve the mechanical and electrical architecture of KuupKulgur. One question we are particularly interested in is how to implement compact, robust and serviceable battery connections in a very constrained rover.
If you have experience with high-current board-to-board, blind-mate or removable battery connectors that have worked well in robotics or other harsh environments, we would be very interested to hear what solutions you have used.
Note:
This development was carried out by **Laur Edvard Lindmaa** as part of his Master’s thesis, *Development of Modular Electrical Power System for KuupKulgur Prototype*, at the University of Tartu.
