About our Silkscreen.
We use Peters SD2692 ink for the silkscreen on our beautiful boards and apply them using the direct printing method.
Do’s and DON’Ts
Do not place silkscreen over pads, we will remove the silkscreen from that area.
silkscreen-over-pad
The minumum distance between a pad and silkscreen is 0.127mm.
pad-silkscreen-clearance
The minimum width is 0.15mm and we recommend a minimum height of 0.8mm for text.
All silkscreen features with a width of less than 0.15mm will be adjusted to 0.15mm.
Do not use the silkscreen to produce large fillings! Designs which cover more than 25% per PCB side will be rejected.
