Team CAPILUX update: the pressure sensor PCBs
Hi again from team CAPILUX! Last time we showed our mainboard and TV mux board. This time it’s the smallest PCBs in our experiment, the ones that sit inside the sealed test chambers next to the liquid.
The test chamber
Each chamber is a 50 mm acrylic tube holding 15 ml of fluid, closed by SLA-printed resin end caps with O-rings. Cameras film the fluid through the tube during flight, so we need light inside it, plus pressure and temperature readings to confirm it stays sealed.
The pressure/LED board
Each board has 3 white LEDs and an ST LPS27HHWTR pressure and temperature sensor, chosen for its water-resistant package. Every chamber gets two boards, one per end cap: one with the sensor and LEDs, the other with LEDs only. The LEDs are potted in epoxy, and we can adjust their brightness from our mainboard.
The first revision used a JST SH connector, which was a mistake. Buried in epoxy, it can’t be repaired, and air leaked out along the cable sleeving. Later revisions use solder pads with wires soldered directly to the board.
Thermal testing
Our simulation predicted the LEDs could reach 93 °C in vacuum, close to their 110 °C limit. In a vacuum chamber below 1 mbar at full brightness, the board settled at about 72 °C, giving us roughly 23 °C of junction margin.
Next steps
Revision 2 boards are integrated and showed live pressure data and adjustable LEDs at our Integration Progress Review. Next we’ll vacuum test the new chamber sealing with the boards installed.
Thanks again to AISLER for sponsoring our boards!
