Unwanted bridges in stencil
Hi!
I am about to order a board and stencil which are similar to a previous one (FZISXSJP).
That previous one had an issue in the stencil i would like to avoid.
The problematic pattern is:
White: Outline, Blue: Copper, Green: Paste, Red: Bridge
The designed paste layer (green) had 4 L-shaped patterns, each edge 20mm long, 0.2mm thick.
The received stencil had those 4 L-shaped patterns but with 5 bridges (red) on each edge.
On the PCB viewer (the step before checking out an order) the stencil was shown without bridges.
Why are those bridges added?
How can i avoid them?
Hey @vj1 ,
sorry that we didn’t answer you yet. I’ve checked with our team: the stencil is cut from exactly what’s on your paste layer, and we don’t add bridges ourselves. So the ones on your received stencil need a proper look at the actual order. Could you send a photo of that stencil with your project reference FZISXSJP to support@aisler.net?
