We are JKU Racing, a newly established Formula Student team from Johannes Kepler University Linz, Austria.
One of our goals when designing our first accumulator was to reduce the complexity of its electrical connections. Conventional battery systems use metallic busbars for high-current connections between cells, while voltage sensing, cell balancing and temperature monitoring typically require additional wiring. For a high-voltage, high-capacity accumulator like ours, this would mean hundreds of individual connections, each of which must be assembled manually and withstand demanding racing conditions.
We therefore decided to take a different approach: Why not combine all these functions into a single PCB?
The result is a multifunctional cell interconnect PCB that provides the high-current connections between cells while integrating the interfaces required by our battery management system (BMS).
One PCB, Multiple Functions
Our accumulator consists of 11 segments, each containing 39 cylindrical lithium-ion cells in a 13S3P configuration. The cells within each segment are arranged in a staggered array, sandwiched between two busbar PCBs.
To eliminate the need for separate cell wiring, these PCBs integrate four essential functions:
High-current connections: Carry the entire tractive system current, making low resistance and thermal performance critical.
Cell balancing: Provide connections through which the BMS can selectively discharge cell groups to equalize their voltages.
Voltage sensing: Use dedicated connections to enable accurate cell voltage measurements while minimizing the influence of balancing currents.
Temperature monitoring: Our digital temperature sensors are soldered directly onto the busbar PCBs, connected through a shared 1-Wire bus and thermally coupled to the battery cells.
Combining these functions into a single PCB significantly simplifies the electrical assembly of each accumulator segment. Another advantage is repeatability: the electrical connections and signal routing are defined by the PCB layout rather than assembled individually for each segment.
The Main Challenge: Carrying High Currents Through a PCB
While carrying currents of a few amperes through appropriately sized PCB traces is usually straightforward, designing PCB interconnects for tractive system currents exceeding 100 A presents a considerably greater challenge.
Unlike conventional metallic busbars, PCB copper layers are typically only tens of micrometers thick. Consequently, conductor resistance, power dissipation and temperature rise become critical design considerations. This challenge was further complicated by the fixed geometry of our cell arrangement, which limited the maximum conductor width available.
However, conductor width alone does not tell the whole story. Narrow sections around cell connections and uneven current distribution can create localized regions of increased current density, potentially resulting in thermal hotspots. These effects also had to be considered when determining the placement of the bond wires connecting the PCBs to the cells.
Achieving acceptable thermal performance at our target current of 120 A, which also accounts for regenerative braking, required several design iterations. Our final revision uses four copper layers, each with a nominal thickness of 75 µm, to maximize the available conductor cross-section within the geometric constraints of the segment. This results in a measured 90°C temperature rise above ambient at a constant current of 120 A. Given that currents of this magnitude will only occur in short transients, this should give us enough margin, even at elevated ambient temperatures.
Combining High-Current Paths with Sensitive Measurements
Integrating power connections and measurement signals into the same PCB introduced another interesting design challenge: The BMS must accurately measure individual cell voltages, even though currents exceeding 100 A may flow through copper areas only a few millimeters away.
These currents create voltage drops across the resistive interconnects, while switching events and balancing currents can introduce additional disturbances. Careful routing and the separation of measurement and current-carrying paths are therefore essential. To address these challenges, we dedicated one of the PCB’s four layers to a continuous reference plane, which helps shield the measurement lines from high-current and balancing paths.
Conclusion
Using PCBs as busbars has allowed us to combine several essential accumulator functions into a single component. Instead of separate cell interconnects, voltage sense wiring, balancing connections and temperature sensor cables, we use an integrated PCB-based solution that simplifies the electrical architecture and makes assembly more repeatable. At the same time, this approach required careful consideration of current-carrying capability, thermal behavior and measurement accuracy.
For us, this project demonstrates how PCB technology can be used beyond conventional electronics to integrate power distribution, measurement and mechanical packaging into a single component.
We would like to thank AISLER for supporting JKU Racing and helping us turn our PCB designs into physical hardware. We look forward to sharing more insights into the electrical systems of our race cars!
