4 layers PCB stackup
I am working on a 4 layers PCB board with some controlled impedance tracks.
I have a doubt on the stackup I should use because I don’t see the same things on the stackup picture on the page below and the prepeg datasheet : different top/bottom copper thickness and permittivity are different. Moreover, whatever is the value, I’m not able to find out how the 50 Ohm track width has been calculated.
And finally, the Kicad rule file seems to says another version for top/bottom thickness (35µm).
Kicad Picture Datasheet
permittivity 4.3 4.3 4.7
Copper top/bot 35um 40um ? 18um ? -
Loss tangent 0 0 0.011
I’m definitely lost.
Can you help me ? Thank you
4 Layer 1.6mm ENIG Design Rules - :sparkles: Beautiful Boards / Design Rules - AISLER Creative Community
Hey @Tynnor,
I’m sorry no one got back to you sooner. I’d still like to answer, since other users might search for the same information: Since you posted, we’ve moved the stackups into their own articles. The one you need is 4 layers 1.6mm 35µm stackup. There’s a separate article if you were on 0.8 mm.
We don’t publish a loss tangent for pooled production. If your design depends on one, get in touch before you order and we’ll look at what’s possible for you.
