Good day, Im happy to know that you add the 6 layer stackup. Do you mind suggest me pls if DK values are fixed or I can adjust it coz I need calculate and design a PCB with some impedance traces. Suggestions are well appreciated
Dear @David_84 ,
EDIT: Thank you for your request. Yes, the Dk-Values (epsilon r) are fixed for this stack up.
Best regards,
Manuel
Good day and thank you for your response, and loss tangent It can be adjust following datasheet..?
Sounds good thank you.
Just in case it’s possible pls update the GitHub repository for the 4 layer also coz I saw also that you are offering the 4L also in 0.8mm.
The 4 layer 1.6mm it’s a little bit different by the previous one coz some of my developments have the previous settings.
