BMS once again new
We updated our BMS, batterie management system, this year. We really needed a new one since the old had some issues.
Our old BMS was composed of 3 components which we solder together and was clunky. We had the main PCB which had the inputs of the sensors for the voltage and temperature. On there a connector PCB was soldered which had 2 plugs on top to connected to the 3rd PCB. This 3rd PCB then connected those plugs with 2 side plug at the side which came from the sensors. This method was awful and gave us a problem where the 3rd PCB was compressed and then plugged itself our of the other PCB which resulted in a failure in our system. This compacted PCB was also needed double the PCB which we the new BMS needs.
The new BMS also fixed a communication problem. The old one had one straight line that went into every BMS and so errors that got into the signal from one BMS was then continued in every Information. The new one fixes that since the Information gets renewed in every BMS so errors gets thrown out and you have a steadier signal.
This is the biggest change we made this year and of the important PCB here so we need a good quality PCB which we get with Aisler.
Thank you for the support and the help we get to make a better car.
