Board-Level Shielding Techniques for Reducing EMI in PCB Design
Hi everyone, I’ve been working on PCB designs recently and came across challenges related to EMI (Electromagnetic Interference). I wanted to understand more about effective board level shielding techniques used in modern electronics. From what I know, shielding can be implemented using metal enclosures, ground planes, and proper component placement. However, I’m still unsure about best practices when designing compact PCBs, especially for high-frequency applications.
Some questions I have:
  1. What are the most effective shielding techniques at the board level?
  2. How important is ground plane design in reducing EMI?
  3. Are shielding cans always necessary, or can layout optimization be enough?
  4. Any tips for balancing cost vs performance in shielding?
I would really appreciate insights or real-world experiences from the community.
Hi user53!
Thanks for using the community forum!
Regarding shielding, effective or necessary measures will depend on what your PCB is doing and how sensitive you want to be about EMI.
In many applications, such as switching power supplies or converters, EMI is extremely difficult to 100% eliminate on a board level, while on most hobbyist projects, EMI is usually not a concern.
To go through your questions one by one:
  1. The most effective board-level technique would be a ground plane. This allows the return paths of high-frequency traces to run wherever they need to (usually right below/over the HF trace) and avoid detours. Another useful tool can be fencing/stitching vias, which aim to ‘cage’ high-frequency noise by placing a lot of GND vias right next to it.
  2. As a direct result, the ground plane would be quite important to minimize EMI, as this allows you to save on material or design work when creating an enclosure. Note that ground planes are often required to make high-frequency designs possible in the first place because they reduce loop inductance and therefore the amount of EMI emitted in the first place.
  3. This will depend on your requirements. Do you want to minimize EMI as much as humanly possible? Then add shielding in addition to PCB best practices. Don’t care as much or don’t have the requirement? You can save a bit here. Minimizing EMI is usually a priority for commercial applications, since they are rigorously tested for EMI compliance before they are allowed to be sold. I suspect most hobbyists will not have such tight constraints, and layout optimization on a PCB level will often be more than enough.
  4. Do as much as you can on the board level. Since more copper on a PCB doesn’t cost you anything, just fill everything with a solid GND plane as a first step. Avoid breaks in the plane as much as possible, and place plenty of vias wherever you need to have them. For most applications, this will be more than enough. Good component placement is also a significant factor in these scenarios, as is trace design.
I can also recommend searching for these topics on places like YouTube, as there are many great visual explanations of this issue that helped me in the past!
Hope this helped,
Felix
