[bug report] Github Login is broken
Using the Github Single Sign-On buttom does not work currently.
I’m writing the from my “second” account, which I am able to use with the email/password login method, but I would be very nice to be able to login to my “normal” account which has a lot of projects and multiple teams.
Clicking on the Sign In with Github button just redirects the the start page (https://aisler.net/). Tested in multiple browsers, all behave the same…
@Patrick-from-AISLER Can you please take a look?
Login with Github is now working again.
not sure … I checked GH login 2 hours ago, and it did work and I could access my projects. I just wanted to continue from there, but I now get
We had problems with our GitHub login. The issue is solved and everything should work now. @oberstet Could you please try again and tell me if the issue persists?
np, thx for the quick reaction and fix! I verified: the gateway issue is gone (seems you are using Cloudflare … +1 btw!), I can login via GH, see my projects, and I also checked one of them in the board inspector. cool=)
It looks that github login (SSO) is broken again, name/password works OK.
The window that suggest being nice blocks part of the input
area and cannot be removed, slightly annoying ;-)…
Could you please send us a message via the support form mentioning the community issue? It would be great if you could add screenshots with the error message to help us to identify the issue as it works for others. Thanks in advance!
