Bug while rendering Kicad file
EDIT: Nah. It’s not a severe bug. But it took 10-15 minutes to process the file which is a bit long for a not super complex 100x100 mm file…
Just for fun I uploaded protoboard/protoboard-10x5-gndplane.kicad_pcb at master Ā· electroniceel/protoboard Ā· GitHub here to see that design was supported by Aislers capabilities.
But 10 minutes later the system is still processing the file. So I guess your renderer/processing scripts doesn’t like that file and goes into a ā€œGuru Meditationā€ :wink:
Congratulations for driving our board processing a bit crazy :confetti_ball: I saw that the design contains more than 37.000 pads, so I guess some meditation was really deserved afterwards :wink:
It does take some time, but after a while the rendering works properly.
I uploaded the files myself a few days ago.
Et tu Brute? :slight_smile: It might be a nice pcb to do mixed smd and thru hole prototyping on. The prototypes will probably be quite sparse so one can’t fit fit too much on a single board. But it would be interesting to try.
