(especially with WS2812 / NeoPixel LEDs)
If you’ve ever seen WS2812 (NeoPixel) LEDs flicker, shift colors or behave strangely at higher brightness, chances are the problem was not software and not the capacitor value.
It was where the capacitor was placed.
The common intuition (and why it fails)
A typical fix looks like this:
Add a big electrolytic capacitor
Place it at the power input
Assume the problem is solved
In reality, this often changes very little.
WS2812 LEDs draw fast, synchronous current spikes.
At the moment these spikes happen, the capacitor may be electrically too far away to help.
What “too far away” really means
“Too far” is not a specific distance on a ruler.
It means the current has to travel through an inductive loop before it can reach the capacitor.
As a practical rule of thumb for WS2812 designs:
≤ 5–10 mm trace length: good
≈ 20–30 mm: marginal
> 50 mm: often useless for fast current spikes
And just as important:
narrow traces make the problem worse
long return paths make the problem worse
Distance and loop shape matter more than capacitance value.
Why WS2812 expose this so clearly
WS2812 LEDs are unforgiving because they:
switch internally with PWM
often change state synchronously
react immediately to small supply dips
The result is visible:
flicker at full white
color shifts
glitches that disappear when brightness is limited
This is classic power integrity, not a logic or firmware issue.
What actually works in practice
1. Placement beats value
100 µF close to the LEDs is better than 1000 µF far away.
2. Think in loops, not lines
Place the capacitor directly between 5 V and GND
Keep both paths short and wide
Minimize the current loop area
3. Distribute, don’t centralize
For multiple LEDs:
use several smaller bulk capacitors
place them near LED groups (e.g. every 5–10 LEDs)
avoid relying on one large capacitor at the connector
Practical PCB guideline for WS2812
A simple, reliable approach:
Bulk capacitor per LED cluster
Trace length to LEDs: under ~10 mm if possible
Wide copper pours for 5 V and GND
Small ceramic capacitors close to the LEDs in addition to bulk caps
This works far more reliably than a single large capacitor at the board edge.
Typical signs your capacitor is “too far away”
If you see these, suspect placement first:
flicker only at high brightness
colors shift when switching to white
first LEDs look fine, last ones glitch
problems vanish when brightness is reduced
Takeaway
A capacitor that’s too far away might as well not exist.
With WS2812 LEDs, inductance beats capacitance.
Place your bulk capacitors where the current is needed, not where there was space left.
