Before starting a new design, where can I find a list of components you typically have on stock?
Even better: do you have a KiCad library with the components you typically have on stock, with all the properties and footprints?
That would make life easier!
Thanks,
Roeland
To give our customers the most flexibility, we typically do not stock larger amounts of components. That is why we do not provide such a list at this point in time, if we change this, I will keep you updated.
For passive components, you can use our smart match tool, which will select the most affordable option for the given specification.
