FR4 TG 150 maximum reflow temperature
I have some boards, manufactured by Aisler, with PCB stackup 4 layer detailed as follow:
  • 4 Copper layers, 1.6mm
  • ENIG Surface Finish,
  • 35um Copper Outer Layers
  • PCB Color Green
  • Silkscreen White
The base material is FR4 TG 150, and I need to solder these boards in a reflow oven.
According to material details, what is the maximum reflow temperature that can be used to avoid persistent damages as burned PCB or any other problem?
Any suggested reflow profile would be of great help as well.
I know that FR4 TG 150, from 150°C transitions from solid to more pliable state.
Thanks,
g.
this is Louis from the Electronics department of the Formula Student Team ELBFLORACE.
We are using similar PCB specifications (FR4) for our own designs and also operate a three‑stage reflow oven with one reflow zone and two preheat zones. Our temperature setup is 140 °C for the first preheat stage, 190 °C for the second, and 260 °C in the reflow zone. The actual reflow occurs after roughly one minute in the reflow area.
FR4 can generally withstand temperatures higher than its nominal rating once or twice during manufacturing, so you do not need to worry about the material being damaged by short exposure.
In your case, the issue is most likely not the PCB material but the components used. Many electrolytic capacitors and connectors, for example, have a maximum temperature rating of around 240 °C, so this must be considered and adjusted accordingly.
Additionally, make sure to adapt the time spent in the reflow zone to the thermal mass of each pad. Large copper areas—such as GND polygons with increased copper thickness—require noticeably more time to reach melting temperature.
I would recommend experimenting with several similar temperature profiles on different PDB boards to find the most suitable setup.
I hope these tips help you in selecting the right temperature profile.
Kind regards,
Louis
