Import shared project only uses default customer
I have several identities(order adresses) at Aisler. Now I try to import a shared project. The project always appears with the first identity. I do not see a way to import the project to the second identity. The shared project needs to be ordered with the second identity. Please allow to select identy when ordering a shared project.
You are right: it is indeed currently not possible to select the team the shared project should be imported to. For the meanwhile, you can order with your other identity/team by moving the project to it. On the project overview page, you have a card that tells to โ€œGet organizedโ€ and allows you move or rename the project. Iโ€™ll take that idea to our development pipeline.
