Invisible capacitive touch button inside a 3D-printed enclosure
I integrated a capacitive touch sensor completely behind a 1–2 mm thick enclosure wall.
No hole, no mechanical button – touch works reliably through the housing, including LED feedback.
The key is not the sensor itself, but the CAD model and printing workflow.
Setup
  • Capacitive touch sensor mounted directly behind the enclosure wall
  • Square touch area in the housing, printed with transparent filament
  • Wall thickness of the touch zone: ~1–2 mm
  • The sensor’s LED shines cleanly through, touch response is stable
Inside view: touch module placed directly behind the enclosure wall.
Tinkercad setup (important)
The transparent touch area must be a separate object.
Object structure:
  • Main enclosure body
  • Transparent touch window (separate solid)
  • Optional: label or symbol (e.g. “OK”) as another separate object
Do not group everything into a single body.
Export:
:backhand_index_pointing_right: OBJ, not STL
  • OBJ preserves individual objects
  • STL merges everything into one mesh → no material assignment in the slicer
In Bambu Studio / Bambu Slicer
  • Import the OBJ file
  • Assign filaments per object:
    • Enclosure → standard filament
    • Touch window → transparent filament
    • Label → contrasting color
  • AMS handles the material changes automatically
Power off: completely smooth surface, no opening, no visible layers.
Power on: LED and label clearly visible through the transparent window.
Pro tip: print orientation
Place the visible and touchable surface of the transparent window directly on the build plate.
Effect:
  • Perfectly seamless surface
  • No layer texture, no sharp edges
  • Slightly diffuse, glass-like appearance
  • Excellent haptics for touch interaction
Transparent filament benefits massively from this – visually and functionally.
Practical notes
  • Keep the transparent wall ≤ ~2 mm
  • Mount the sensor as flat as possible, minimize air gap
  • Rectangular touch areas work more reliably than very fine shapes
  • Prefer a smooth build plate (smooth PEI or glass)
Short version:
Capacitive touch + multi-material printing + proper object separation + smart print orientation
= a clean, robust button without any mechanics.
Once you’ve built it like this, mechanical buttons feel outdated.
Optional: haptic feedback via vibration motor
If you want active haptic feedback, you can add a small vibration motor (coin or cylinder type).
  • Driven directly from a GPIO, transistor, or motor driver
  • Short pulse on touch event → clear tactile confirmation
  • Works well in combination with the seamless touch surface
  • Especially useful when the LED is not visible or in bright environments
This keeps the UI fully sealed while still providing physical feedback.
Note: For sharing this guide with the community, Marcus has received 50€ AISLER Store Credit. :orange_heart:
Do you have a tool, a script, or a project that others could learn from? View our Announcement to find out how you can earn credit for your next order by posting a guide!
