Hi. I’ve made a new revision of my board and now i cannot upload the KiCad pcb file. It stops with error and suggest to contact support (what i did twice, but no answer yet). As i want to use assembly I have only the option with Kicad pcb file or ODB++. But Kicad is not supporting ODB++ export natively. Uploading gerber files works fine and pcb can be rendered with a warning “removed copper around NTPH”. Uploading an example designs is working. Probably someone from community can suggest a solution. Thanks
Found the issue by myself. Two footprints had an image object. Just removed it and could import pcb file.
