Mastering 600 Volts: Inside UgentRacing’s High Voltage PCB
In a Formula Student electric racecar, managing the sheer power of the battery pack is just as important as putting that power down to the road. Sitting right inside our Tractive System Accumulator Container (TSAC), the High Voltage (HV) PCB is one of the most critical safety subsystems on our vehicle. It acts as the ultimate bridge between our safe Low Voltage System (LVS) and the massive potential of our Tractive System (TS).
Mixing low-voltage logic with nearly 600V requires strict galvanic isolation, large creepage distances, and a flawless manufacturing process. That is why we rely on Aisler to produce our HV PCBs. Their high-quality fabrication gives us the confidence that our isolation barriers will hold up under extreme track conditions.
Here is a deep dive into the circuitry of the HV PCB, how it manages our high-voltage systems, and how it keeps our engineers and drivers safe.
Controlled Power Delivery: Precharge and AIRs
Connecting a 600V battery directly to empty inverters would result in a massive, destructive spike of inrush current. To prevent this, the HV PCB meticulously controls our Accumulator Isolation Relays (AIRs) and the precharge sequence.
  • The Sequence: When the driver activates the car, the HV PCB first closes the negative relay (AIR-) and a dedicated Precharge relay.
  • The Precharge: This routes the high voltage through a precharge resistor, slowly and safely charging the capacitors inside the inverters.
  • The Handoff: The board continuously compares the vehicle-side voltage to the accumulator-side voltage. Once the vehicle-side voltage reaches 95% of the accumulator voltage, the precharge is considered complete. Only then does the board close the positive relay (AIR+) and open the Precharge relay, making the car fully ready to drive.
Unhackable Safety: Implausibility Logic and TSAL
Because software can freeze, Formula Student rules require the Tractive System Active Light (TSAL) circuitry to be fully hard-wired and independent of software. Our HV PCB uses purely analog logic gates to verify that the vehicle is behaving safely.
The board constantly monitors the physical states of the relays to check for “implausibilities”. For example, if the logic detects that both the Precharge relay and AIR+ are closed at the same time, a physically impossible and unsafe state for our pre-charge configuration, it triggers a hardware latch. This latch immediately drops the system into a safe state and remembers the error until the low-voltage power is manually cycled.
The board also handles the logic for the Green TSAL, outputting a highly visible green light signal only when three strict conditions are met:
  • No implausibilities are or have been present.
  • The AIRs and precharge relays are completely open.
  • The voltage on the vehicle side of the relays has dropped safely below 60V.
The High Voltage Indicator (HVI)
If there is dangerous voltage present inside the TSAC, we need to know about it—even if the car is turned off. To comply with this, the HV PCB features a High Voltage Indicator (HVI).
  • Independent Operation: This red LED indicator must operate completely independently of the Low Voltage System, remaining functional even when the LVS is shut down or disconnected.
  • Custom Power Conversion: To achieve this, we designed a complex ultra-wide input buck converter. This circuit taps directly into the high-voltage lines, stepping the 588V down to 12V.
  • Always Watching: If a voltage greater than 60VDC is present on the vehicle side of the relays, this circuit powers itself and continuously illuminates the red LED at full brightness to warn the team.
Bridging the Gap with Aisler
The HV PCB is incredibly dense. Not only does it manage complex 588V-to-12V step-down converters, but it also routes numerous low-voltage signals across optocouplers to cross the isolation barrier safely. Getting this layout right, ensuring proper keep-out zones and creepage distances between the 600V traces and the 24V logic, is a massive layout challenge.
Prototyping and manufacturing complex, mixed-voltage boards like these leaves zero room for error. Aisler provides the precision we need to ensure our designs are safe, rule-compliant, and track-ready. Thank you to the Aisler team for helping UgentRacing push the boundaries of electric performance safely!
