MEMS microphone soldering
I was wondering if AISLER is able to solder MEMS microphones. As far as I know they sometimes need a special reflow soldering profile. I want to use this microphones. Can I use them if I want to have the PCBs produced by you?
Best regards
Tom
The curve provided in the datasheet is a typical JDEC lead-free reflow curve. Which means no special requirements have to be met. E.g. Yes we can do that.
Thank you very much!
The datasheet also lists a couple of assembly hints on page 15. Can you confirm that you can also manage this?
Best regards
Tom
We can accommodate all of these requirements. Please contact our support staff prior to placing the order so we can forward it to the assembler.
