Hi there !
I’m starting a new project with a custom rotary encoder PCB… A tiny one for a specific use in a control panel :
I’m using KiCad 9 with the (excellent) Kikit plugin to make a “PCB panelization” :
I add 2mm tabs and space but I’m not sure if it is possible to AISLER to build this PCB panel, any tips or advices ?
Big thanks, have a good week
Michael
uwe
2
Do you nedd the PCB panalized? Otherwise load up the single board and order the number of boards you need (modulo 3).
Hi @uwe,
It’s easier for me, for soldering SMD resistors and other components.
I tried to checkout : (one board) x 9 and (2x2 boards) x 3, this last result price/quantity for 12 boards (with stencil) is good for me
Thanks
Here my final result : 2x2 boards with a shell script to easily generate panels…
#!/bin/bash
# TinyRotaryPCB with KiCad and KiKit plugin for PCB panelization
# KiCad documentation : https://www.kicad.org
# KiKit plugin documentation : https://github.com/yaqwsx/KiKit
# Input and output files
INPUT_FILE="TinyRotaryPCB.kicad_pcb"
OUTPUT_DIR="panel"
OUTPUT_FILE="${OUTPUT_DIR}/TinyRotaryPCB_panel.kicad_pcb"
# Layout parameters, by default 2x2 -> panelize.sh <rows> <cols> parameters
LAYOUT_ROWS=${1:-2}
LAYOUT_COLS=${2:-2}
LAYOUT_SPACE="2mm"
# Tab parameters
TAB_TYPE="fixed"
TAB_HWIDTH="2mm"
TAB_VWIDTH="1mm"
TAB_VCOUNT="2"
# Framing parameters
FRAME_TYPE="railstb"
FRAME_WIDTH="2mm"
FRAME_SPACE="2mm"
# Text parameters
TEXT_HEIGHT="0.8mm"
TEXT_VOFFSET_POS="1mm"
TEXT_VOFFSET_NEG="-1mm"
TEXT_JUSTIFY="hjustify: center; vjustify: center;"
POST_MILLRADIUS="1mm"
# Ensure output directory exist
mkdir -p "$OUTPUT_DIR"
# Kikit command with all parameters
kikit panelize \
--layout "grid; rows: ${LAYOUT_ROWS}; cols: ${LAYOUT_COLS}; space: ${LAYOUT_SPACE}" \
--tabs "${TAB_TYPE}; hwidth: ${TAB_HWIDTH}; vwidth: ${TAB_VWIDTH}; vcount: ${TAB_VCOUNT}" \
--cuts vcuts \
--framing "${FRAME_TYPE}; width: ${FRAME_WIDTH}; space: ${FRAME_SPACE};" \
--text "simple; text: {boardTitle} {boardRevision} ${LAYOUT_COLS}x${LAYOUT_ROWS}; anchor: mt; voffset: ${TEXT_VOFFSET_POS}; height: ${TEXT_HEIGHT}; ${TEXT_JUSTIFY}" \
--text2 "simple; text: Created on {boardDate}; anchor: mb; voffset: ${TEXT_VOFFSET_NEG}; height: ${TEXT_HEIGHT}; ${TEXT_JUSTIFY}" \
--post "millradius: ${POST_MILLRADIUS}" \
"$INPUT_FILE" "$OUTPUT_FILE"
# Check if the command succeeded
if [ $? -eq 0 ]; then
echo "Panelization successful : $OUTPUT_FILE"
else
echo "Error : Panelization failed"
exit 1
fi
Cheers !
