With KiCAD 10.0 on macOS, the plugin Push to Aisler does not work. The small dialog stops at “generating manufacturing assets…”.
The same file works with KiCAD 9.0.8 with the plugin.
Hi Peter,
could you check if you’ve installed the latest 0.3.2 version from our package repository? The procedure is explained at GitHub - AislerHQ/PushForKiCad: AISLER Push for KiCad EDA · GitHub
Cheers,
Patrick
Thanks for pointing this out, I had version 0.2.5 installed. It came from the default package kicad repository.
I can confirm your latest version 0.3.2 is working fine with the latest KiCAD version 10.0.0 on macOS.
Would it be possible to update the KiCAD repository more often as this is not a feature update but really a bug fix.
Unfortunately the official KiCad repository won’t be updated anymore. All new versions will be provided on our own repository as this allow faster version cycles.
For sure, but updates from time to time to the official repository would certainly make it first-time users much easier to access your services. This is especially important if the official version is basically broken, as new users will expect the same quality from your PCB service as from the plugin, and thus not place orders.
