Show component prices in the BOM
I’m always annoyed when ordering with amazing-assembly that I only see a total price for the BOM components. The individual component prices are only displayed with a rough scale of four euro symbols.
This makes it difficult to spot errors or optimise component costs.
Displaying the prices would have several advantages:
  • Recognise if the MPN has been entered for a whole roll by mistake, resulting in an unnecessary order.
  • Recognise where there is potential for optimisation. Expensive individual components would quickly stand out, enabling you to look for alternatives.
  • If a single component is the only part purchased from a separate supplier due to lack of availability, extra delivery charges are incurred for this component only. If I could see this, I could consider using an alternative component instead.
In my opinion, this would be a very useful feature, providing more transparency on component costs in the BOM.
We are always open to better communicate BOM pricing! When starting Amazing Assembly a few years ago, we displayed prices. Unfortunately, instead of improved comprehensibility, it sparked confusion. Our algorithms are optimizing for the lowest assembly cost of the total price for a dedicated quantity. It therefore respects various aspects, e.g., additional manufacturing buffer (which, e.g., depends on assembly method and the component price and type).
We therefore decided for a scale, allowing identification of cost drivers. Would a more fine-grain scale improve your situation?
I am curious about the full reel MPN issue, do you have an example for me?
Out of curiosity, which kind of components would you consider easy to replace / the best candidates for optimization?
I do not believe that the problem can be solved by a finer-grained scale.
An example for 10 boards:
The most expensive component on my board costs €20 x 10 = €200.
If I now enter the MPN CQ03SAJ010102T5E for the 1k Ohm resistor, then the whole reel will be ordered, which costs 5 euros instead of, for example, taking the CR0603-FX-1001ELF for 11 cents for 10 pieces.
If the displayed scale divides the range 0-200€ into 4 steps, it is not possible to see on the scale whether the resistor is being purchased for 5 euros (reel) or 11 cents (cut tape).
If I were to see the prices directly, I would immediately realise that €5 for a 1k resistor cannot be right.
If you want to keep to a scale, then such errors can only be recognised if the scale has an increment of 50 cents, for example - i.e. 400 scale lines in the example shown. This will not work.
So in my opinion, the only way to find such errors is to display the component prices.
Thanks for the example, I see the difficulty here and take this to our internal discussions how to improve the BOM displaying.
I would like to comment that this is a critical issue with the BOM management tool.
I’m finalizing the BOM on a design that we prototyped last year with 3 units. Ordering the original design at 3 units saw the original price go up by a factor of 3. We know the assembly pricing model changed in January, but that was quite a surprise.
I kept searching which part was adding the cost. We have a 15 euro connector which is marked as “3 euros” in our BOM. But then we also have a 50ct MOSFET (placed 2 times on our board) that was marked as 4 euros. It didn’t highlight any information on HOW that part was adding this much cost. Presumably the system wanted to order a whole reel of 2.5K units? (815 euro at Mouser)
I now changed out that MOSFET for a slightly cheaper part (30ct vs 50ct at 100 pieces). At qty=3 the price even went 200 euros below what we paid last year! And basically all quantities between 5 and 500 are 1200 euros cheaper now too. Only at 1000 units its finding price parity (considering the part costs 20ct less).
For such small runs its always a trade-off between time spent optimizing vs the attainable savings. However, saving 1200 euros in 5minutes should not be a difficult or mysterious procedure! I want to have this information, because considering there are 90 BOM lines on this board, its non-trivial to spot these things.
The relevant part numbers are DMPH6050SK3Q-13 (old) and DMP6180SK3Q-13 (new).
