Text Knockout in Kicad 7
Hello Aisler-Team,
knockout for references does not work as seen in the picture on Kicad 7.0.1-3b83917a11~172~ubuntu22.04.1
Greetings Andrej
The Inverted Silkscreen dissapears when exporting a Gerber from the Kicad project. This is a Issue with Kicad not our viewer.
I imported the .kicad_pcb file, not the Gerber file.
Update: If I use the “push to aisler” plugin it works perfect.
Does this now mean that it is a kicad problem? Is this problem known to the kicad-team?
After upload we are always generate a Gerber from the EDA files for creating the panels. What you see in the viewer is 1:1 the Gerber file which will be put on the panel for production.
I just checked my Kicad Version and its the release build from Kicad 7 so maybe it was an Issue which was fixed in the meantime.
I will look into it.
This is Indeed a Issue which was fixed with the newest update.
Thanks for your help!
Our software pipeline is now updated.
