Transferring no-fit/variant info from design tools
Apologies if this feature already exists and I failed to find it…
I have an Altium design where I don’t want all the parts fitted, so I used Altium’s variant management system to set up a variant with the correct parts fitted. I used the push-to-Aisler (ODB) system, and selected the variant for the output job before clicking ā€˜Generate and publish’.
But when I looked at the design in the Aisler website, all the parts were listed for fitting, even those I had set to be omitted in the variant.
I ended up manually configuring each part that needed to be omitted from the build, a tedious and error-prone process.
Can we have a better way (not manual entry of each part) to specify which parts are to be fitted, instead of just assuming every part in the PCB design is to be fitted? If there was a way to separately upload a BoM, as others have requested, that would be an acceptable solution which would work for all design tools.
In addition, I suspect that if I had used the variant system to change the fitted parts for some locations, that information would not have been transferred over either. Again, a BoM upload facility would be a solution for that.
Hi @matten! Just to be sure we are talking about the same: fitted mean whether they should be included in assembly and are not marked as excluded in BOM, right? We import this information from ODB++, so those parts should automatically be marked as excluded. Can you provide me some details how the fitting decision flag is stored in Altium? You can also DM me the project token, so I can take a look at the generated ODB++ file.
Yes, I think we’re talking about the same thing - whether each component should be fitted/placed, or no-fit/excluded. This is part of what you can set up as a ā€˜build variant’ in Altium, together with making changes to the type of part that is fitted.
I think that Altium stores the variant information in the ā€˜ProjectVariantN’ sections of the .PrjPcb file. I don’t know enough about ODB to know whether this type of information is usually sent to the ODB output data.
I will DM you the project ID.
I took a look at the ODB++ file. It does not contain any information whether the part should be excluded/not fitted. I am sorry, as long as it is not included I am afraid we will have no chance to automatically import it.
My only suggestion is to take a closer look at how the ODB++ export within Altium is configured. I noticed that the latest documentation mentions a checkbox to include variant configuration in the export, see Preparing Fabrication Data | Altium Designer 24 Technical Documentation. You can give it a try and if it does not work send the file in via a support email referencing this topic.
OK, after enabling ā€˜ODB.Improvement’ in the Advanced settings window to enable this ā€˜open beta’ feature in Altium, there is now an option to ā€˜Include Variants Data’ in the ODB++ configuration options.
With this enabled, I can see that there is now variant information in the odb\steps\pcb\layers\comp_+_top\components file. Each component now has a ā€˜PRP VARIANT_INSTANCE’ line that lists all the variants for which the component is placed/fitted. Note that data for all variants are included, choosing a variant for the output doesn’t seem to have any effect on the ODB data.
I tried pushing this to Aisler (I will DM you the project ID), and no parts were marked as excluded. This doesn’t surprise me, there would have to be a way for me to select which variant was wanted before this could work.
Worse that that, I tried changing the value of a resistor as part of the variant definition, and while this did generate ODB information in the form of a ā€˜PRP ASSY_PN_OVERRIDE’ line for the component, as far as I could tell the only information about the component variation was an internal part number for the new resistor value, so there is no MPN for you to look up.
It’s your decision, but it seems to me that your best option would be to add support for a CSV BoM upload, rather than trying to support a beta feature of Altium that doesn’t include all the necessary information for varied parts.
Thank you for investigation! Under these circumstances, I agree that it will be hard to automatically exclude those components or import actual MPNs for variations.
In the case you need to get multiple variations of the same board assembled, please contact our staff for a dedicated offer.
Looking at the ODB++ spec, I see that BoM information is meant to be stored in a steps/<step_name>/boms/<bom_name>/bom file, but Altium is not generating this, whether or not the beta variant output feature is enabled.
If I were to add this file myself, would it be understood and used by your import tools?
The standard defines this file indeed. Unfortunately, only some PCB design tools fill those files, so Altium is not special here. And those that do it, do it with incomplete information and add the interesting fields as properties in the components file. We therefore extract all necessary fields from there. I guess that is the difference between the specification and how a standard is actually lived.
Do you plan to put the effort in it because of the automatic exclusion or the automatic assignment?
I’m considering writing a Python script to modify the ODB++ data to apply both part exclusions and part replacements according to the Altium variant data.
From what you have told me, if I do write this then I should make it change the components file rather that try to create a bom file. This is useful to know, thanks.
Dear Aisler!
Please note this issue has not been resolved as of today. In the Altium odb++ files, all variants are written out. However, in Aisler it is not possible to choose which Variant will be used.
It would be great if you could improve the upload and give the user more options.
BR,
Fabian
I asked GPT to write a script that takes the ODB+, PnP file from Altium and removes components not used by the variant. It works like a charm.
yes this works but it’s a workaround. It should be possible to do this in the Aisler interface. Until then i continue using Eurocircuits as it offers this option.
It’s not an Aisler issue, but Altium! The non-populated components are still in the ODBC but marked as not mounted. But only some of them are marked this way…In my case, only 2 types were marked correctly; the rest were not marked at all.
Thanks @grzegorz-kasprowicz for bringing this back up! Unfortunately, we currently know about no other solution, but to wait for Altium to adapt it fabrication outputs. As far as we can see, the Variant Manager is still in Open Beta.
@fabian-luttenberger If you are fine doing this manually, you already are able to exclude all components not relevant in the interface on the BOM page.
Nevertheless, since the last time I checked, Altium updated it documentation. Could you do me a favor and check whether you employ variants as described in the documentation Working with the Variant Manager | Altium Designer Technical Documentation. Do you use the modern or the standard version?
And how do you generate the fabrication data? Preparing Fabrication Data | Altium Designer Technical Documentation Do you use the improved dialog option? Based on the documentation, the current active variant should be exported as long as you do not enable the ā€œInclude all Variants Dataā€.
It would be great if a configuration/documentation would solve the issue. Thanks in advance for your efforts!
Hi, is there a method when sending the design via Kicad to mark parts that are to be excluded from Assembly (and left for manual assembly by the customer).
Eg in the same way a MPN symbol field can inform part matching.
It does seem the Kicad DNP flag has some effect in a new upload, putting parts in the exclude category, but I’m not sure this is by design or not. It does not seem consistent when uploading updates which change the DNP status of a part.
Thank You. Simon
Good point. Indeed, the DNP flag is currently only respected at initial import and changes have no effect on subsequent uploads. I will add this to our development pipeline. We are currently planning to improve the part updating process on subsequent uploads, so we will take a look at this as well.
Thank you Tim, for the timely response and consideration. Regards, Simon
