UL mark
Hi guys,
do you apply a UL mark to the PCBs you produce? That would be essential to me.
I’ve added a field in bottom mask or silkscreen where it’s stated “insert UL mark”.
Would you fill this and how could I point or ask ou to insert this into the PCB?
I will have to ask about the UL mark. But you would need to insert it yourself as we do not review the files manually, we use a software pipeline to process the design files automatically.
Works for me. In that case I would need a picture or similar which I could insert into KiCAD, any layer. Preferbaly Silkscreen or Mask layer.
We can provide you a UL mark for larger orders but not for boards from our prototyping series.
OK. What would “larger orders” mean? Currently I can only see the option of beautiful boards and amazing assembly.
I would just like to indicate that the PCBs are UL compliant. This is normally the case for FR4 material. I think you are not using sth. else?
Is there anyother option to show that? Maybe a unique UL number is not necessary but just to show it’s compliant.
Our prototype boards (those offered in our pooling service) are not UL certified. If such boards are required, you can contact our support Team, and we can see which UL certified options could be possible when ordering larger quantities of board orders.
