Via capabilities for ESP32
Hi!
I am creating a desgin where I am using a ESP32-S3-WROOM-2 with this footprint..
The problem is that in the center of the components there are some GND pads and vias (0.2mm hole & 0.4 total diameter) that seem to be smaller than manufacturing capabilities.
Any advise on how to add those pads and vias to make it manufacturable without compromising its functinality?
Thanks in advance.
Hi Pedro :wave: Since the vias and pads all belong to the same net, it is not an electrical issue to enlarge them. It would look like this.
Please note that the soldermask expansion set by SnapEDA is unnecessarily large, I’d set that value to something more reasonable or keep it at 0 µm.
Another approach I would recommend is to place the vias around the pads, this ensures that no soldermask can wick into the vias. By doing so, you can also use a larger via diameter and potentially even our budget option.
I hope this helps :slight_smile:
