2 Layer HD Design Rules
Last Updated: 22/05/2024
Design Rule Files
Do you want to start right away? We provide design rule files for Eagle, KiCad and DipTrace on Github .
The rules listed here shall always be used as reference.
PCB Dimension
min. dimension | >10 mm / >0.4 in | ||
max. size | 400 x 400 mm / 15.74 in x 15.74 |
Surface Finish
We use Electroless Nickel Immersion Gold (ENIG) as surface finish for our 2 Layer HD PCBs, this surface finish offers good surface planarity and high oxidation resistance.
surface finish | ENIG | ||
Nickel thickness Gold thickness |
4.0 µm -7.0 µm 0.05 µm -0.1 µm |
Minimum Copper Features
Description | Capability | |||
min. tracewidth | 125 µm / 5 mil | ||
min. SMD pad size | 200 µm / 8 mil |
min. spacing copper / copper | 125 µm / 5 mil | ||
min. spacing NPTH / copper | 250 μm / 10 mil | ||
min. spacing NPTH slot <1.8 mm / copper | 300 μm / 12 mil | ||
min. spacing NPTH slot >= 1.8 mm / copper | 300 μm / 12 mil | ||
min. copper to edge clearance | 300 μm / 12 mil |
Plated Through Hole (PTH)
All drills with a diameter larger than 0.45 mm are categorized as plated through hole for component mounting, we will enlarge the drill diameter to compensate for the copper plating thickness to ensure that components can be mounted more easily.
min. PTH drill size | 0.5 mm / 0.02 in | ||
max. PTH drill size | 5.6 mm / 0.22 in | ||
min. PTH annular ring | 300 μm / 12 mil |
Vias
All drills with a diameter up to 0.45 mm are categorized as via drill and will not be subjected to any adjustments by us.
min. via drill | 0.25 mm / 10 mil | ||
max. via drill | 0.45 mm / 20 mil | ||
min. via annular ring | 100 μm / 4 mil |
0.5 mm / 20mil | |||
5.6 mm / 0.22 in |
Minimum Drill Spacing
min. drill spacing | 300 μm / 12 mil |
NPTH Slots
NPTHs Slots that are smaller than 1.8 mm are nibbled. This is a time-intensive process, so we reserve the right to limit the use of nibble slots in a design. Diameters above 1.8 mm will be milled and are thus preferred.
preferred NPTH slot diameter | >= 1.8 mm / 0.07 in | ||
min. NPTH slot diameter | 0.8 mm / 0.032 in | ||
max. NPTH slot diameter | ![]() |
PTH Slots
min. PTH slot diameter | 0.7 mm / 0.028 in | ||
max. PTH slot diameter | 2.6 mm / 0.11 in | ||
min. PTH slot annular ring | 300 µm / 12 mil |
Silkscreen
We use Peters SD2692 ink for the silkscreen on our PCBs and apply it using the direct printing method. The smallest supported width is 150 µm / 6 mil, all silkscreen features with a width less of that will be adjusted. Silkscreen printed on pads is not supported, we use openings in the soldermask as reference to cut away / remove the silkscreen in the affected area. Do not use the silkscreen to produce large fillings, designs which cover more than 25% per PCB side will be rejected.
min. silkscreen text height | 800µm / 32 mil | ||
min. spacing silkscreen / pad | 125 µm / 5 mil | ||
silkscreen on pad | not supported | ||
min. spacing silkscreen / edge | 400 µm / 16 mil | ||
max. Silkscreen | 25% of Board size |
Soldermask
We use high-quality Peters Elpemer AS 2467 SM-DG green soldermask which is well suited for the ENIG finish. Please refer to our soldermask specification for the electrical properties of the soldermask.
min. soldermask dam | 75 µm / 3 mil |
Castellated Edges
Castellated edges are offered in our 2 Layer HD pool free of charge, please refer to our documentation on how you can set them up.
castellated edges | Supported |
Additional Notes
- Buried, blind, micro or tented vias are not supported.
- User-defined subpanels are not allowed, see also here.
- Pressfit components are currently not supported.
