Last Updated: 24/04/2024
Design Rule Files
You want to start right away? We provide design rule files for Eagle, KiCad and DipTrace on Github .
PCB Dimension
min. dimension
>10 mm / >0.4 in
max. size
400 x 400 mm / 15.74 in x 15.74
Surface Finish
We use Electroless Nickel Immersion Gold (ENIG) as surface finish for our 4 Layer HD PCBs, this surface finish offers good surface planarity and high oxidation resistance.
surface finish
ENIG
gold thickness
0,05 µm -0,1 µm
Minimum Copper Features
Description
Capability
min. tracewidth
125 µm / 5 mil
min. SMD pad size
200 µm / 8 mil
min. spacing copper / copper
125 µm / 5 mil
min. spacing NPTH / copper
250 μm / 10 mil
min. spacing NPTH slot <1.8 mm / copper
300 μm / 12 mil
min. spacing NPTH slot >= 1.8 mm / copper
300 μm / 12 mil
min. copper to edge clearance
300 μm / 12 mil
Plated Through Hole (PTH)
min. PTH drill size
0.5 mm / 0.02 in
max. PTH drill size
5.6 mm / 0.22 in
min. PTH annular ring
300 μm / 12 mil
Vias
min. via drill
0.25 mm / 10 mil
max. via drill
0.5 mm / 20 mil
min. via annular ring
100 μm / 4 mil
0.5 mm / 20mil
5.6 mm / 0.22 in
Minimum Drill Spacing
min. drill spacing
300 μm / 12 mil
NPTH Slots
preferred NPTH slot diameter
>= 1.8 mm / 0.07 in
min. NPTH slot diameter
0.8 mm / 0.032 in
max. NPTH slot diameter
No restriction
PTH Slots
min. PTH slot diameter
0.7 mm / 0.028 in
max. PTH slot diameter
2.6 mm / 0.11 in
min. PTH slot annular ring
300 µm / 12 mil
Silkscreen
We use Peters SD2692 ink for the silkscreen on our PCBs and apply it using the direct printing method. The smallest supported width is 150 µm / 6 mil, all silkscreen features with a width less of that will be adjusted. Silkscreen printed on pads is not supported, we use openings in the soldermask as reference to cut away / remove the silkscreen in the affected area. Do not use the silkscreen to produce large fillings, designs which cover more than 25% per PCB side will be rejected.
min. silkscreen text height
800µm / 32 mil
min. spacing silkscreen / pad
125 µm / 5 mil
silkscreen on pad
not supported
min. spacing silkscreen / edge
400 µm / 16 mil
max. Silkscreen
25% of Board size
Soldermask
We use high-quality Peters Elpemer AS 2467 SM-DG green soldermask which is well suited for the ENIG finish. Please refer to our soldermask specification for the electrical properties of the soldermask.
The following track layouts can be used to realize defined impedance. Please note that these values only provide a basic orientation. Interference factors such as angles, meanders or vias in the routing of the tracks may negatively affect the intended impedance.
Defined Impedance
Type
Impedance
Signal- / Reference Layer
width
space
width
Single Ended
50 Ω
TOP / IN1, BOT / IN2
245 µm
Differential pairs
90 Ω
230 µm
165 µm
230 µm
Differential pairs
100 Ω
190 µm
180 µm
190 µm
Additional Notes
Buried, blind, micro or tented vias are not supported
User-defined subpanels are not allowed, see also here
