In the past I often ordered stencils without PCBs if I needed a PCB that could not be made by Aisler, e.g. flex boards.
In the newest design change this is not possible anymore and I have to order FR4 boards (which I don’t need) to get a stencil.
Please allow again to order a stencil alone
Same! Sometimes I already have boards for existing projects that I would like to get a stencil for, getting PCBs when you only need a stencil is quite wasteful.
would also like this option. I just ordered some new boards (that I don’t need) in order to get a stencil.
Similar problem here!
When putting the initial order I forgot to order the stencil . Production for that order has not yet started. I do not see any way add the stencil order. Please consider!
same, forgot mine also.
I am also looking for an option to order stencils only
I just need a replacement stencil and came back to Aisler because I knew it was possible a couple of years ago. Very disappointed to see this amazing service gone.
Please bring this back!
Sometimes you simply overestimate your own soldering capabilities (or the size of the components you are dealing with).
At least I do, so it would come in very handy if I could turn to my manufacturer of choice for this without buying additional boards. Please consider (re)adding this feature - best combined with Allow to select only TOP/Only Bottom/Both stencils.
Warm regards,
Yannik
I’m also in need of just stencils for some boards I already have, would be very nice to be able to order them on their own!
I’d like to order only a stencil, too.
