Assembly Portfolio
Our Assembly Products
We provide high-quality assembly solutions tailored to your specific needs. Our offerings include:
  • Amazing Assembly – Ideal for rapid prototyping with cost-effective, low-quantity production.
  • Scalable Series – Designed for validated designs, ensuring seamless scalability for high volume production.
Feature Amazing Assembly Scalable Series
Recommended for Prototyping Series
Self-checkout available :white_check_mark: :x:
Blitz service available :white_check_mark: :x:
Detached panels :x: :white_check_mark:
Production sample included :x: :white_check_mark:
Automated Optical Inspection (AOI) on request :white_check_mark:
IPC-A-610 Class II / III Compliance :x: on request
Options
The following options are available upon request. Contact our account management team for more details.
Option Details
Soldermask colors Black, White, Red, Blue, Yellow, …
Material FR4 (Tg – HTg), Rogers, Aluminium
Surface finish ENEPIG, Hard Gold
Layers > 4
PCB Thickness 0.2 mm - 3.2 mm
Finished Copper Thickness β‰  32 Β΅m
PCB Certification UL, RoHS
Packaging PCB Compartment Boxes
Testing and programming According to your Specifications
Boxbuild According to your Specifications
Advanced Via Technologies On demand
Our capabilities
We offer the following capabilities for Amazing Assembly & Scalable Series:
Assembly Specifications
Minimum order quantity 1
Maximum order quantity :infinity:
Doubled-sided possible :white_check_mark:
THT Components allowed :white_check_mark:
SMD Components allowed :white_check_mark:
THT & SMD mixed allowed :white_check_mark:
PCB Size Limits for self-checkout *
Maximum PCB width 43.0 cm
Maximum PCB height 47.0 cm
*For different PCB dimensions, please contact our Account Manager
Component Specifications
Smallest SMD footprint possible 0201
Minimum pitch for active components 0.35mm
Minimum pitch for passive components 0.4mm
Minimum pitch for BGA 0.4mm
Customer-supplied components possible
Solder Paste Specifications
Solder paste Leadfree RoHS
Leadtime
Lead time See our: Service Status
Blitz Assembly
Availability Only for Amazing Assembly
Lead time (simple board configuration) See our: Service Status
Conditions
Condition
Manual optical inspection Included, based on project documentation
Shipping dates Estimates may vary depending on production and delivery status
Panelization Amazing Assembly PCBs are delivered in panels unless otherwise requested; for depanelized PCBs, contact our account management team
Stack-ups & surface finishes Refer to our standard stack-up in the PCB design rules; custom options available upon requestβ€”contact our account management team before ordering
Solder paste residues May remain unless complete washing is requested
Unused through-holes Can be sealed with solder unless otherwise requested
Stencil data usage Stencil data is used as provided, including all openings for fiducials or unplaced components; paste will be fully applied accordingly
Please refer to our general terms and assembly specific terms for more information.
