When ordering a assembly you can choose whether we at AISLER should source the components for you or if you want to supply them yourself.
You can benefit from live price and stock information from within our BOM tool thanks to the tight integration with our preferred distributors. This allows you to easily order assembled boards using the webinterface without going back and forth in E-Mails. Thanks to higher volume ordering you may also get better prices than ordering it yourself. In case you need a component from a non-preferred distributor you can contact our project managers who will manage the sourcing for you.
Preferred Distributors |
Würth Elektronik |
Mouser |
Digikey |
Farnell |
Arrow |
This is a list of Distributors we source from but do not have a direct integration in our BOM tool. Contact our Project Managers if you want to source components from these or other Distributors.
