First things first, we prepare your design files for manufacturing using an automated software pipeline. If you have any questions or want to make remarks, please contact our support before ordering, as we do not read notes included in your project files.
If that is done, navigate to Output -> ODB++
This will open a window with multiple options.
Leave the Compressed checkbox ticked, so you donโt have to manually compress the files before uploading.
Make sure to include all necessary layers. If you use a custom layer like aisler-bridges, include it in the output. You will need to assign the Silkscreen, Soldermask and Solderpaste layers. Without these layers, we are unable to manufacture your boards.
Do Not check Omit EDA or Omit Netlist, selecting these options removes data that is required for assembly and e-testing of the PCBs.
You can use Neutral Names to replace your net names with generic ones, but we donโt recommend it because it makes it harder to compare the e-test report with your layout.
When everything is set up, press OK and save the .tgz file. The file will usually be saved in your project directory or at the location specified.
Now upload the file to our website, we will automatically generate the production data from it.
