First things first, we prepare your design files for manufacturing using an automated software pipeline, if you have any questions or want to make remarks, please contact our support before ordering, as we do not read notes included in your project files.
If that is done, navigate to Fabrication Outputs -> ODB++
Add a job name or leave it blank to use the project name, then select either Tarball (.tgz) or ZIP archive (.zip) as output option. Select the filename and output path, press Generate to save the ODB++ file.
