First things first, we prepare your design files for manufacturing using an automated software pipeline, if you have any questions or want to make remarks, please contact our support before ordering, as we do not read notes included in your project files.
If that is done, navigate to Output β ODB++
This will open a window with multiple options.
Make sure to include the required Fabrications (Fab) and Assembly (Assy) layers. If you use a custom layer like aisler-bridges, include it in the User Layers section.
Do Not check Remove EDA data, Remove Cadnet Netlist or Ignore component layout, selecting these options removes data that is required for assembly and e-testing of the PCBs.
You can use Neutralize nets to replace your net names with generic ones, but we donβt recommend it because it makes it harder to compare the e-test report with your layout.
Tick the Compress Output checkbox so you donβt have to manually compress the files before uploading.
When everything is set up, press OK and save the .tgz file. The file will usually be saved in your project directory or in the location specified in your output configuration.
Now upload the file to our website, we will automatically generate the production data from it.
