About this tutorial
AISLER understands Gerber files generated from National Instruments Ultiboard. This tutorial shows you in four easy steps how your Ultiboard export will always succeed when imported.
Step 1: Use our Export configuration
- Download the NI config-File for AISLER on our Github
- Store it on your PC.
Step 2: Rename your gerber files in the following format:
| Gerber Layer Name | Layer |
| project_name.toplayer.ger | Top Layer |
| project_name.bottomlayer.ger | Bottom Layer |
| project_name.topsoldermask.ger | Top Soldermask |
| project_name.bottomsoldermask.ger | Bottom Soldermask |
| project_name.topsilkscreen.ger | Top Silkscreen |
| project_name.bottomsilkscreen.ger | Bottom Silkscreen |
| project_name.boardoutline.ger | Board Outline |
| project_name.xln | PTH Drills |
| project_name_npth.xln | NPTH Holes |
Step 3: Zip them up
Please zip your Gerber-Files
