We want to make using AISLER’s services as easy to use as possible. For that reason, we offer native integrations for as many design tools as possible. Click on your tool below for detailed instructions on how to prepare manufacturing data in the simplest way.
Your design tool is not listed here? No problem, we support all design tools that can generate ODB++ as manufacturing output. Nowadays, all common tools support it. Refer to the documentation of the tool you use. We are happy to include your tool in the list if you can provide us instructions and some screenshots how to do it! For every other application, we support traditional Gerber files.
Please also check our list of Known PCB design tools issues and limitations.
| Beautiful Boards | Amazing Assembly | Simple Supply | Scalable Series | Native Project File Import | Push to AISLER | Smart Test Support | |
| KiCad | |||||||
| Altium Designer | |||||||
| Target3001! | |||||||
| Autodesk Eagle | |||||||
| Autodesk Fusion360 | |||||||
| DipTrace | |||||||
| Fritzing | |||||||
| LibrePCB | |||||||
| Sprint Layout | |||||||
| Altium Circuit Studio | |||||||
| Designspark | |||||||
| Labcenter Proteus | |||||||
| ODB++ Upload | |||||||
| Gerber Upload |
Important: No assembly is possible with traditional Gerber files, please consider using the native file format of your preferred CAD application. For more details, see our explanation Advantages of uploading PCB board or ODB++ files.
