We support Altium Circuit Studio ODB++ files, and prepare your design files for manufacturing using our automated software pipeline. If you have any questions or want to make remarks, please contact our support before ordering, as we do not read notes included in your project files.
How to prepare Circuit Studio ODB++ Export
If that is done, navigate to Outputs -> Fabrication -> ODB++
This will open a window with a few options. You can set which layers to include in the ODB++ file export and which layer will be set as ODB++ profile layer.
Make sure to include all the relevant copper, soldermask, paste and silkscreen and component layers. Set the layer you used for the outline to be included in the ODB++ profile layer.
When everything is set up, press OK and save the archive file. Now upload the file to our website, we will automatically generate the production data from it.
Known PCB Design Tool issues
Issue: Component Part Numbers are not included in the ODB++ export.
Circuit Studio version: All
Description: The Component Part Numbers are not included in the ODB++ Output, and thus they need to manually entered in our BOM tool when an assembly is desired.
Workaround/Fix: None, the MPNs need to be manually entered. Circuit Studio was last updated 5 years ago, and unlikely to ever receive bug fixes. We recommend Altium or KiCad as alternative E-CAD programs.
