Please improve warning that CSV BOM is not accepted
please rephrase following text on BOM tab of projects
Your project currently contains no components
Here, you could see and manage your components to order an assembly. With us, you do not need to manually handle additional files to provide us component and placement information. Instead, we extract all details from your project file. You only have to upload your design as ODB++ or native board file. Check out our design tool support matrix for more details on how we support your design tool. If you want to know more about the benefits of this approach, see our community.
to something like
Here, you could see and manage your components to order an assembly. There is no way to get assembly done by us unless you provide data by something from design tool support matrix.
I wasted like half of an hour trying to figure out how to upload BOM csv…
Thank you.
Thanks @Pavel, we will make the hint a bit more explicit!
An ancillary question here: what tool do you use that does not support ODB++ (or we do not support directly) so that you tried to upload a BOM CSV?
Hello @Tim-from-AISLER, Easy EDA by JLC PCB.
Great to hear, then you are able to profit from easy uploads using ODB++ as this is supported! Just follow the instructions here: Export ODB++ from EasyEDA.
